- Joined
- Jun 28, 2007
- Messages
- 415
- Reaction score
- 0
Good morning,
We are testing V5 for a deployment this comming month.
We are having a problem getting the lines through BroadVoice to register.
The 3CX server is a dedicated server with a static public IP.
I attempted to set up broadvoice using the template in 3CX but this failed so I set up the BroadVoice line using the generic template. I entered the information as I did with 3CX V3 but the line will not register. When I go the the Edit page for VoIP gateways there are a variety of fields missing that where there in V3 (ie. Outbound Proxy Hostname or IP, Specified IP, etc.).
The 3CX V5 server appears to be using a stun resolved IP address instead of the static IP which is needed.
How do I set up the BroadVoice line using a static public IP address and how do I modify the settings once it is set up as I was able to in V3?
Thanks again
Thanks again
