How to setup each VOIP Provider/Gateway for each extension.
Discussion in '3CX Phone System - General' started by Anonymous, Oct 16, 2006.
  1. Anonymous
    Anonymous Guest
    How to setup each VOIP Provider/Gateway for each extension to forward SIP calls to PSTN, so I can use different VOIP Gateway/Provider for different countries.
  2. Anonymous
    Anonymous Guest
    I already configure.
    I already configure, so no need to reply, please.
  3. Anonymous
    Anonymous Guest
    Hello Kamran.
    Would you mind sharing with us your outbound rule configuration please?
    I'm having difficulties doing what you have already worked out :)
    My current issues can be seen in the "3CX in Australia" thread.
    I can't seem to control which voip provider is used when making outbound calls to different countries.
    For example, when any extension dials say 44xxxxxxxxxx I want that call to be routed through to my sipgate (UK) provider.
    Likewise, if any extension dials 61xxxxxxxx then I want that call to be routed through to my faktotel (AU) provider.
    Any help would be greatly appreciated.
    Thanks, Mark.
