How to setup unlisted voip provider?
Discussion in '3CX Phone System - General' started by Multiman, Apr 2, 2008.
  1. Multiman
    Apr 2, 2008
    I would like to set up my voip provider but am having no luck registering. These are the settings I have from them.:
    User ID: 1250412767
    Password : mnopqr
    Proxy Server Address: did.voicenetwork.ca
    Stun Server: stun.voicenetwork.ca
    I am able to register in "Trixbox" using:
    1250412767:mnopqr@did.voicenetwork.ca/1250412767
    I would appreciate any help.
    Thanks in advance
  2. h2009
    h2009 Member
    Mar 15, 2008
    447
    have you check which port they need you to use? 5060 is default,but it can be 5065.
    Also do they have an outbound proxy?
    What about sip registration timeout?
    Are you sure there systesm work with 3CX?
    (if you need a provider, which works well let me know)
