How to shut-down 3CX server?
Discussion in '3CX Phone System - General' started by BenYL, Mar 26, 2010.
  1. BenYL
    Jan 22, 2010
    Maybe this is obvious, but does anyone know how to shutdown the 3CX server? Also, is there a way to not have the server automatically start-up when Windows boots?
    Ben
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Answers are windows log and PBX log. (startup)
    Shutdown is available even from management console.
  3. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    Strange question...
    1. Use net stop command or shutdown command.
    2. Set Service Startup Type - Manual in Services MMC
