How to support voip and analog together?
Discussion in '3CX Phone System - General' started by markv, Oct 7, 2012.
  1. markv
    Sep 17, 2012
    9
    Can someone explain how to support ringing at both a voip phone and an anlog line together? We have a customer using analog handhelds which respond on the same extension number as there desk voip phone.
    Should I do difficult tricks like creating groups or is there an easy solution like for example assigning the same extension numer twice?
    Greets, Mark.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    I actually have 2 SIP handsets in my office that ring the same extension, especially when I am testing.
    You should be easily able to assign an analog adapter and a SIP phone to the same extension.
    One of the two will need to be manually set-up.
  3. leejor
    11,125
    330
    Having multiple VoIP PBX extensions (or even just VoIP phones with the same phone number) is called SIP forking. Some PBX's/VoIP providers allow it, some don't...3CX does.
    If you want to use an analogue set in the VoIP world, you have to use an ATA (analogue Telephone Adapter) with it. I'm not sure if there is a limit, but a number of devices, VoIP phones and ATA's, can be assigned the same extension number, and will ring simultaneously when called.
  4. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    You can use an ATA and setup as the same extension as the desk phone and both will ring, vice versa you can assign the analog lin a different extension. When registering your ATA with Analog device you will be able to assign that device to any extension youd like.
