how to un install 3CX
Discussion in '3CX Phone System - General' started by cristina, May 26, 2008.
  1. cristina
    Apr 23, 2008
    12
    I would like to stop running 3CX but i dont know how to do it. Do I need to uninstall it for that? is there any option in the GUI for that? I cant find the way to do it...
  2. cristina
    Apr 23, 2008
    12
    Re: how to stop running 3CX
    i got it. thanks anyways.
  3. thomasz
    May 20, 2008
    10
    How do you do that? Please give me advice.
  4. ess
    ess New Member
    Jun 8, 2007
    133
    On the server running the 3cx phone system, hit ctrl shift escape. Click on the services tab, and stop 3cx the services one by one. Good luck!
  5. Andy Schmidt
    Andy Schmidt New Member
    Apr 3, 2008
    118
    It's a frequently asked question. Instead of having to explain it each time and people creating batch scripts - it SHOULD be an option in the Web Admin GUI. I should be able to manage the entire 3CX system from it's own Web Admin GUI as if the server was a black-box or applicance that is locked away and has no monitor or keyboard (which truly may be the case!)
  6. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,973
    283
    To uninstall piece of software in Windows, you go to Add Remove programs. If this is not something you like, then dont use Windows!
