How to update to SP3 through Management Console
Discussion in '3CX Phone System - General' started by edokim, Feb 14, 2018.
Tags:
  1. edokim
    Nov 29, 2017
    49
    My updates section through the Management Console (on GCP) is still only showing Beta version. Am I missing something? How do I update to Build 15.5.8801 through the console?
  2. jimbo59
    jimbo59 Member
    Nov 17, 2017
    358
    79
    I would hold off. There issues with SP3. Look at it as a blessing that it didn't upgrade.
    DanFisher likes this.
  3. accentlogic
    accentlogic New Member
    Nov 14, 2013
    190
    79
    Looking forward to SP4 alpha, beta, release candidate, and then final when the RC is certified.
