How to Upgrade from Version 8 to 9
Discussion in '3CX Phone System - General' started by gary2seven, Jul 7, 2010.
  1. gary2seven
    Sep 18, 2009
    48
    We purchased 3CX SBE last November with upgrade insurance.
    There are some features on Version 9 we would like to and want to take the opportunity to move the 3CX to a 100% dedicated machine.
    Can someone advise the best upgrade process? Should we copy everything across from the old machine to the new machine on version 8 and then upgrade? Or do we do a clean Version 9 install and then import the settings (I think we can save settings on old system) ?
    How does the system recognise our license, or do we need to get a new one?
    Gary.
  2. carolinainnovative
    May 4, 2009
    369
    5
    The system should recognize your license. Backup the old system on v8 on the old machine using the 3cx backup/restore tool. Install v9 on the new machine. Restore the pbx using the 3cx backup/restore tool. Go through and change any settings that were IP specific if you're changing your IP as well. Then go to the license page and make sure it picked up your license.
    It is as simple as that.
  3. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    If ip changes, or mac changes (since it is a different iP) your license will need to be activated again.
    If you do not have an internet connection on the new machine, your license will not succeed.
    If you have an activation request will be sent and your pbx will be licensed no problems.
    If OS is different, example migrating from server 2003 to 2008 you need to change certain entries that are path related like documents and settings vs program data.
  4. gary2seven
    Sep 18, 2009
    48
    We migrated from Vista to Windows7, then restored settings from backup. Except for forwarding rules (which have changed in version 9) everything transferred correctly and all looks licensed and verified.
    we changed the IP address of the new machine to match the old one and everything worked first time, amazing!
    36 hour on and not a single issue with Version 9 RC - great work guys!
    Gary
  5. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,405
    81
    Thanks for the comments,
    If you have any problems at all with V9, just let us know.
