How to use IVR and Call Queues ?
Discussion in '3CX Phone System - General' started by migors, Nov 21, 2017.
  1. migors
    Nov 13, 2017
    21
    Could you point me how to achieve this in pro version?
    I need simple scenario 1. Voice prompt. 2 music on hold. 3 another voice prompt if bussy. 4 music on hold. 5 another voice prompt with voice mail if selected option to leave message and again from start.
    If i try to do this with Call Queues it says that no agents are available but ip phones are working. Does the Call Queues work only with soft phones?
    I use google cloud and remotely connected ip phones. May be that is a problem?
    Any help highly appreciated. Thanks
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,248
    202
    After adding the extensions into the queue, you need to make sure there are logged into the queue
    Goto Extensions, highlight the phone and click on 'Status' - Change Queue status to loggedin
  3. migors
    Nov 13, 2017
    21
    Oh thanks, it helped.
