How to use TFTP
Discussion in '3CX Phone System - General' started by Alliedbs, May 30, 2009.
  1. Alliedbs
    May 29, 2009
    19
    anyone know how to use the TFTP to connect to the cisco ip phone. Please Advise. Thanks.....
  2. sipero123
    Nov 24, 2008
    94
    I've little internet access at present but if you search on the forums you'll find the postings that i and others have made on this.
    Jonathan Hamon
  3. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    It's the other way around - you use a TFTP server and the Cisco phone connects to it upon start-up.
  4. home
    Feb 25, 2009
    31
    First of all you need a TFTP server, I would recommend Solarwinds from http://www.solarwinds.com ( its free )
    Secondly, once you have installed Solarwinds you need to go to the "File" tab and then "Configure" and then "Security" and select "Send and Receive Files".
    Solarwinds is now configured and ready to go, you need to place your SIPDefault.cnf , SIP(Mac).cnf and your SIP image in your TFTP root folder.
    Now you need to make sure your DHCP server setting are correct, under "Scope Options" you need option 003 Router, 006 DNS Servers and 066 BootServer Host Name,
    With all this setup power on your Cisco phone and hold down the "#" button until it says "Reset key sequence detected", then enter "1,2,3,4,5,6,7,8,9,star,0,hash" then press "2" and phone will say "Factory Reset Initiated". This forces the phone to get a new dhcp lease and therefore pick up all the above settings.
    If all works okay the phone should optain all its network setting from the DHCP server and its SIP image and SIP setting from the TFTP server.
    I hope this helps.
  5. Alliedbs
    May 29, 2009
    19
    Can anyone tell me where to look for "Scope Options" under windows xp home and i how to load the file to the TFTP servers?? Please Advise.
  6. home
    Feb 25, 2009
    31
    Windows XP does not have a DHCP Server, only Windows Server Editions come with this, with regards to the files for TFTP, you normally just copy and paste your files into the TFTP Root folder created by the install in the root of C:
  7. Discovery Technology
    Apr 19, 2008
    278
    There are several free downloadable DHCP Servers available that can run on Windows XP - I have used one called "Dualserver" for my demo environment - works well enough and you can set the TFTP server option for your Cisco handsets, so it comes in very handy...
