How to write logs at external script
Discussion in 'Call Flow Designer' started by Larikov Sergey, Mar 5, 2018.
  1. Larikov Sergey
    Mar 2, 2018
    Hello! I started to build automatic dialer with CFD and there was a question about logging at external script.
    I copied the code from the topic
    https://www.3cx.com/community/threads/find-amount-of-available-call-queue-agents.49551/
    http://myprintscreen.com/s/rgn2/2d13dd2d69
    And everything works as it should and thanks to the author for code :)
    However it is necessary to do additional logging at this code but I can not to do this.
    In file "3CXObjectModel.2.0.0.0_v15.chm" I found that PhoneSystem contains the necessary interface http://myprintscreen.com/s/rgn5/20dbe7cef8
    I added a line of code to the FreeAgentsCount.CountFreeAgents
    PhoneSystem.Logger.Error("THISasdjasjlksdk182793 unique string for test");
    I build the project, upload it, restart queue and it works at it should.
    But here in any messages at log files (i try to find at '3CXQueueManager.log' and other 3CX log files...)
    Please tell me how to log messages in external script and where are they stored?
    Thank you for your help and time.
    #1 Larikov Sergey, Mar 5, 2018
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,609
    126
    Hello @Larikov Sergey,
    The logger used by CFD apps, which logs to the 3CXQueueManager.log file, is not exposed to the scripts, so you can't use it to log from your script. You can use the Logger component to do it, but you can't call a Logger component from your code...
    I'm not sure where the Logger property from the PhoneSystem class writes the log, but anyway it should be pretty simple to create a simple method to log to your own text file, something like:
    Code:
    public static void Log(string fileName, string text)
      File.AppendAllText(fileName, text + Environment.NewLine);
    Kind regards.
  3. Larikov Sergey
    Mar 2, 2018
    @edossantos thanks for the solution. This is the easiest way.
    Here is the final solution for 'Log' function
    Code:
    public static void Log(string text)
                string fileName = "/var/lib/3cxpbx/Instance1/Data/Logs/FreeAgentsCount.log";
                string logMessage = String.Format("[{0}]: {1}", DateTime.Now.ToString(), text + Environment.NewLine);
                File.AppendAllText(fileName, logMessage);
