How too call sip url, Not supported ?
Discussion in 'Windows' started by capron, Jun 24, 2010.
  1. capron
    Jun 24, 2010
    I only use 3cx phone client program and can not call sip urls it it not supported in free version ?
    Whant too call
    Google Search engine sip:18004664411@tf.voipmich.com
    SIP ehf. echo test sip:4151595@services.sip.is
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,479
    67
    if you used the syntax above, sip:..., 3CXPhone will handle correctly. However, this is not enough - the PBX or voipprovider you're connected should ALSO support direct SIP calls.
    Hope it helps
    Regards
    vali
  3. matictec
    matictec New Member
    Mar 31, 2008
    188
    I have the problem, that I can do not enter the "@". What could be the problem.
