- Joined
- Nov 23, 2007
- Messages
- 43
- Reaction score
- 0
after strugling some time to get it to work, I just thought it could be helpful for you all to share my experiences and write a HowTo about setting up your 3CX server as a LDAP server, so Cisco IP phones in your network can pull directory information from it. It'll also work on external LDAP servers (I just preferred to run it on the same box, after all in my case it's just a home network)
The attached file contains some of the needed files, plus an install.txt file describing the necessary steps.
I could unfortunately not attach all files, due to upload size limitation. Added a link in the install.txt file though, pointing to where you can find these files.
With a LDAP server in the network, I only have to maintain one addressbook, and both my CIsco IP-phones (7960) as well as the outlook email clients all can pull information from it.
Hope this is helpful for other users trying to do the same thing. Drop a private message or a reply, should you have some questions.
Regards,
Arnaud
Regards,
Arnaud
