HT503 Help
Discussion in '3CX Phone System - General' started by amygoda, Mar 20, 2008.
  1. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello
    Can you help me set Grandstream HT503
    problem no1: it ansower the pstn call and transfer it to the ext.
    problem no2: caller id does not work
    thank you
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Don't wast your valuable time to make works on caller id. It should be the firmware issue.
    Please refer to HT488's setting 3cx.com/voip-gateways/GrandStream-HandyTone488.html - this link is no longer available, visit here: https://www.3cx.com/voip-gateways/.
    It should be almost the same setting.
    #2 5qg4, Mar 20, 2008
  3. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello 5qg4
    Thank you for your ansower
    I installed the latest firmware and still has this problem
    and what you yhink about orher problem (open the pstn line and give the caller ring tone with out ext ansower
