HT70X 3CX v14 compatible?
Discussion in '3CX Phone System - General' started by axudar1, Aug 17, 2015.
  1. axudar1
    Nov 11, 2013
    6
    Will the HT70X series from Grandstream be compatible with 3CX version 14? Some of my clients have devices running on them. In 12.5 is showable and configurable, but the v14 is the option absent.
    10,587
    253
    There should be no technical reason that they would not work. They could be moved over "as configured", or set-up manually, as a worse case scenario. Auto configure templates for use with 3CX may be available from the manufacturer. I would check with them.
  3. axudar1
    Nov 11, 2013
    6
    There used to be a template for the HT70X series. But in the V14, there isn't. I configured them manually, and it's working.
  4. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Is it possible to add template for Grаndstrеаm phones in V14, seems 3CX is not allowing adding custom templates ?
