HTC Desire HD - receive but can't call
Discussion in 'Android' started by magelan2000, Jan 20, 2011.
  1. magelan2000
    Jan 20, 2011
    Hi everyone!
    Did anyone come across this issue that upon registering Sipgate.co.uk SIP account, call's come in and sound good but absolutely cannot make a call? The call button simply doesn't react...
  2. dandee
    Jan 21, 2011
    no not yet, I'm still trying to figure out the SIP account issue, what have you got so far, thanks.
  3. 400ixl
    Jan 21, 2011
    Works for me.
    I select the person icon to bring up the contact list. Find the contact I want and long press it. The list of options comes up and I select the call (mobile / Home / etc) I want and it dials it.
  4. papa
    Jan 24, 2011
    same here Just installed 3cx phone 1.2.9 on an android 2.2 on a htc desire the green buton wont make a call it works fine on a IPhone 4 the blue ring comes up around the button so it is registering the touch and i can recieve calls
  5. leejor
    11,078
    324
    I've found the same problem when trying to use 3G, even a VPN connection to home network over 3G (wifi works, for the most part). Dial the number but touching the call key has no effect other than the blue border coming on when the key is pressed. Phone shows registered, but remains onhook.
  6. hainesk967
    May 23, 2011
    38
    Make sure you have your outbound rules set up correctly and either assign them to the extension or extension group that you are using with your HTC phone.
  7. leejor
    11,078
    324
    This was/is, not an outbound rules issue. The call was not even leaving the phone. In my case, the latest version of the 3CX Android phone corrected it.
