HTC Sensation XL issue
Discussion in 'Android' started by ArjanVl, Jun 26, 2012.
  1. ArjanVl
    Oct 18, 2011
    5
    Hi There,
    Installing and running the app is fine. Have some issues though:
    - Selecting a contact, I can only dial the primary number of the contact
    - the prefix +31xxxxxx is interpreted as 031xxxxxx resulting in a failed call
    Works fine as I just type in numbers... but cant remember all contacts numbers u know :)
    Cheers,
    Arjan
  2. ArjanVl
    Oct 18, 2011
    5
    Forgot mandatory info:
    Device Info
    Phone Model: HTC Sensation XL
    Firmware Version: 4.03
    3cx Version: 4.05
    Issue Info
    Handset: [Phone|Heatphone with MIC|BT]
    Contacts: Local (google synced)
    Connection: WiFi &3G
    Server:|External
  3. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    I think that 3cx does not support "+" as prefix...
