Http and 3cx
Discussion in 'CRM / Helpdesk / App Integration' started by Fabione, Mar 2, 2017.
  1. Fabione
    Feb 25, 2017
    14
    Hello, I'm new of 3CX and I have a question.
    I have a 3cx pbx and a Door station of Lilin with a relay that open a door.
    It is SIP and the audio/video work good.
    The Lilin door station haven't a dtmf code to open relay but have only a string http to open relay like this:
    Code:
    http://192.168.0.200/setio?relay1=1 and http://192.168.0.200/setio?relay1=0 to stop the opening.
    Is possible to program 3CX to assign a code (for ex: *123) to launch that string ?
    Thanks in advantage and sorry for my bad english.
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,080
    77
    Hi @Fabione,
    You can create a VAD application to invoke that HTTP request. Then you call the extension of the VAD app and maybe the app can ask you to enter a DTMF to open or close the door.
    It would be similar to what we show here:
    https://www.3cx.com/blog/docs/accessing-web-service-vad/
    But using a Web Interaction component instead of the Web Services Interaction component.
    Please note that the VAD is available for v14 only now. The Service Pack 6 of v15 will include the VAD for v15.
    Kind regards.
    Ernesto.
  3. Fabione
    Feb 25, 2017
    14
    2n9et8g.jpg Morning Ernesto, I just installed the VAD for V15.5 and it works good.
    I make a new very basilar project that has two http request:
    Code:
    It work with a queue exstension but I need to add a delay (4 or 5 seconds) after the first http request, any suggestion ?
    Thank you very much.
    #3 Fabione, Jun 12, 2017
  4. edossantos
    Jun 27, 2007
    1,080
    77
    Hi @Fabione,
    In order to add a delay, you can use a "Launch External Script" component, and use the following C# code for it:
    Code:
    using System;
    using System.Threading;
    namespace DelayNamespace
      public class Delay
        public void DelayExecution(int milliseconds)
          Thread.Sleep(milliseconds);
    Then you can invoke that code configuring the Launch External Code component as follows:
    Kind regards.
  5. Fabione
    Feb 25, 2017
    14
    Thank You Ernesto, I tested it and It works but not everytime, sometime I call the extension and the second http request do not start ...
  6. edossantos
    Jun 27, 2007
    1,080
    77
    Fabione likes this.
  7. Fabione
    Feb 25, 2017
    14
    I open the log and I found a banal error on http requests, now everythings is working good !!
    Thank you so much for the rapid and resolutive help !!!! :):):)
    #7 Fabione, Jun 12, 2017
    edossantos likes this.
