HTTP API in 3CX phone system v9?
Discussion in '3CX Phone System - General' started by lewang, Dec 13, 2010.
  1. lewang
    Aug 16, 2010
    8
    Is the HTTP API also available for 3CX phone system version 9? I noticed that it's part of version 8 but could not find any documentation indicating its presence in version 9. If I want to use the HTTP API, do I have to revert to version 8?
    Thanks,
    Lei
  2. AdgTech
    Dec 3, 2010
    11
    It still exists. Just follow the directions here: http://www.3cx.com/blog/docs/3cx-http-api/
    Also, if you're using Abyss make sure to add the /ivr/ to the path.
