HTTP Based API for make call
Discussion in 'Windows' started by anuradha, Oct 27, 2015.
  1. anuradha
    Oct 27, 2015
    We have a web application and we are trying to integrate 3CXPhone app for that. We just need to make a call by clicking on an icon. My question is does 3CX has a http based API for that ?
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Thank you for your email,
    You may use the TEL protocol where any web link starting with "tel:" is sent to dial through 3cxphone.
    More information can be found on http://www.3cx.com/blog/voip-howto/tel-protocol-3cxphone/
    This feature requires a Pro license.
