HTTP lookup caller ID source
Discussion in '3CX Phone System - General' started by mrapoc, May 3, 2016.
  1. mrapoc
    May 3, 2016
    Hey all
    Looking to try out 3CX and migrate from freepbx if it ticks all the boxes of the current system.
    Currently we use a HTTP lookup to an API on our repairshop CRM which will show the correct caller ID, if there is a job outstanding and also log a call on the customer section.
    Details here: http://feedback.repairshopr.com/knowled ... ntegration
    I couldn't see this feature - is it called something else or is there an alternative way to do it?
    10,360
    226
    Don't see Repairshopr specifically mentioned, you might want to question them about integration with 3CX. I see that someone has already brought up 3CX in their forum. Perhaps they require a nudge.
    http://www.3cx.com/crm-integration/
  3. mrapoc
    May 3, 2016
    Yes maybe they do :) is it easy enough to implement the API?
    Proper integration rather than http api would result in a lot more features I guess - but still there isn't a way to put in a http source in 3CX for caller ID lookup in the meantime?
