Huge amount of Log entries generated since V6
Discussion in '3CX Phone System - General' started by justin, Jul 8, 2008.
  1. justin
    Feb 20, 2008
    79
    I upgraded from V5.1 to V6.0.612.0 a few days ago. 5.1 worked great no major issues but since upgrading to 6 my error log contains a HEAP of errors that are appearing every 2 secs.
    Initially where it said From: "MakeCall" it was alternating between Ext. 80, 82 and 85 (80 - 85 are digital receptionists) so I thought that maybe something went funny in the upgrade so I deleted all the receptionists in the hope that it would dissappear but now get the following:
  2. Henk
    Henk Member
    Nov 13, 2007
    250
    Re: Huge amount of errors generated since V6
    Did you restarted the server after the upgrade?
    H.
  3. alsoft
    Jun 27, 2008
    35
    I solved major issues with a fresh installation of 3CX 6. Uninstall 3CX, clean up your registry, install again.
  4. justin
    Feb 20, 2008
    79
    Well I couldn't upgrade actually it was giving a lot of problems, so I actually did a clean uninstall and reinstall deleting all configuration settings etc. after backing up, then once V6 was up I ran a restore.
  5. Henk
    Henk Member
    Nov 13, 2007
    250
    You must restart after license activation, that made my errors disappear.
  6. justin
    Feb 20, 2008
    79
    Rebooting fixed it :)
    Seems kinda stupid to have to do that. Maybe they should implement an internal restart of the server when a licence is updated :lol:
  7. Henk
    Henk Member
    Nov 13, 2007
    250
    A well, you cannot have it all really :).
    H.
