Huge delay on out going calls
Discussion in '3CX Phone System - General' started by spec, Sep 29, 2006.
  1. spec
    Sep 8, 2006
    51
    The 3cx is generating a delay every time you make an out going call.
    My provider is
  2. spec
    Sep 8, 2006
    51
    As there has been on response over the last few days can I assume you are unable to resolve this problem???
  3. ace
    ace
    Oct 4, 2006
    5
    I'm having the same problem of a very long delay before the phone really starts ringing.
    Haven't tried the older beta, but a softphone doesn't give this problem with me.
  4. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,007
    309
    Not seen this problem
    We have not been able to recreate this situation. We have tried with numerous providers: SIpgate, Nikotell, Vonage and none of them have displayed this behavior. I suggest that you try with our new beta 2 build, which has better error logging, and should be available over the next 2 days. Please also let me know which provider you are using.
  5. ace
    ace
    Oct 4, 2006
    5
    I have only tried with voipbuster (http://www.voipbuster.com) yet.
  6. Nick Galea
    Jun 6, 2006
    2,007
    309
    Please try again
    We have tested with VOIP buster and did not have the same problem. We just uploaded a new beta 2 (5 oct 06), with much better error logging. Please try with that and let us know how it goes.
  7. ace
    ace
    Oct 4, 2006
    5
    The new beta doesn't have the delay, thanks!
  8. spec
    Sep 8, 2006
    51
    Thought I should eliminate the pc that 3cx is running on as being the problem . So I installed it on to a newly built server with no other software on for it to conflict with. To save me reconfiguring the pbx I backed up 3cx and tried to restore the backup on to the new install (on the new server). This is the error it gave me.
    Warning: Invalid argument supplied for foreach() in C:\Program Files\3CX\PhoneSystem\Data\Http\functions\BackupManager.php on line 279
    There is no data file inside the archive. #0 C:\Program Files\3CX\PhoneSystem\Data\Http\functions\BackupManager.php(161): BackupManager->clearData() #1 C:\Program Files\3CX\PhoneSystem\Data\Http\admin_general.php(59): BackupManager->doRestore('C:\WINDOWS\TEMP...') #2 {main}
    So what should I do restore or do I have to do it manually ????????
  9. spec
    Sep 8, 2006
    51
    Sorted restoring the backup
    I wrongly presumed you unzipped the file before installing the backup
  10. Nick Galea
    Jun 6, 2006
    2,007
    309
    Any luck
    Did you have any luck with the delay being removed in the latest beta?
    Sorry about the backup issue - we changed the format because we thought zip would be user friendlier for most. Sorry about the inconvenience.
  11. Anonymous
    Anonymous Guest
    Just installed latest copy and still a long delay
    I would say that the situation is tolerable, but I downloaded and installed the latest version and I am noticing a delay. I called my office at work which I know picks up in 3 rings and I didn't hear any of them and suddenly my voice was playing the message.
    I am using a cable broadband connection; could that be why?
  12. Nick Galea
    Jun 6, 2006
    2,007
    309
    Delay
    3Cx phone system is not inserting any delay. It could be that the VOIP provider has some sort of delay, depending on the speed of the internet connection and how busy they are. But in any case 3CX is forwarding the SIP requests as they come in to the VOIP provider....
