Hunt by (x)
Discussion in 'Ideas' started by zenpc, Feb 1, 2017.
Hunt by (x) 4.7 5 3votes
4.7/5, 3 votes
  1. zenpc
    Feb 26, 2009
    Allow the number of agents hunted to be configurable. So instead of either 3 or nothing, change this to a number as required.
  2. TSlocum
    TSlocum New Member
    Oct 15, 2013
    225
    15
    Second this. It would be immensely helpful!
