I am looking for a variable/function reference for VAD
Discussion in 'Call Flow Designer' started by datamerge, Jun 22, 2017.
  1. datamerge
    datamerge New Member
    Nov 19, 2014
    169
    19
    Hi All
    Is there a variable/function/object reference for VAD? E.G. DateTime is an object that has many members, but I can't find anywhere to drill down alphabetically on any of these objects and I have not found a document that lists them.
    Regards
    Mark
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,083
    77
    Hi Mark,
    You can use any C# expression in the new CFD, so you need to take a look to the Microsoft documentation to get a full list.
    If you don't know how to do anything let us know and we'll point in the right direction.
    Kind regards.
  3. datamerge
    Nov 19, 2014
    169
    19
    Thanks Ernesto.
    I thought that might be the case. I had found the entire DateTime structure from MSDN. That is good to know. Takes me back over 20 years to my CPP days. :)
