i am looking for a voip phone provider for a call center
Discussion in 'Windows' started by mtaks09, May 30, 2010.
  1. mtaks09
    Dec 7, 2009
    22
    i am looking for a voip phone porvider for a call center. all the voip poviders i see have a call center clause in the terms of use. does anyone know where the best place to find a provider that will fit my needs
  2. carolinainnovative
    May 4, 2009
    369
    6
    Re: i am looking for a voip phone porvider for a call center
    You didn't specify a country - so here's my answer for USA:
    http://www.broadvox.com/SIP-Trunking-contact.aspx
    They specifically speak to Call Centers and the like. Several other voip providers do as well - even several of the "pre-set" ones listed in 3cx.
    I personally use NexVortex and they have a few products that they say can be used with call centers, phone card resellers, etc.
  3. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    How big of a call center? I think that is really the deciding factor.
  4. mfm
    mfm Active Member
    Mar 4, 2010
    641
    Its not how big the call center its how many call do you get in at a time? That I think is the deciding factor.
  5. KerryG
    Jun 19, 2009
    960
    One would assume that the larger the call center the more concurrent calls you will get, hence the entire purpose of a call center.
  6. mtaks09
    Dec 7, 2009
    22
    right now we are just a 3 man operation but i dont want to be running then the phone shuts off
  7. carolinainnovative
    May 4, 2009
    369
    6
    I'd say both of my recommendations can handle that plus a WHOLE HECK OF lot more.
  8. carolinainnovative
    May 4, 2009
    369
    6
    Here are a few others:
    http://www.gafachi.com/ - good wholeale rates
    http://www.globalcrossing.com/ - unknown rates
  9. mackallen
    Dec 18, 2012
    If your company is in Texas, check out Folkerson Communications LTD. They are one of leading providers of VoIP phone providers in the area. Outstanding services at affordable cost.
