I assume this is by design?
Discussion in '3CX Phone System - General' started by Pentangle, Dec 16, 2007.
  1. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    So, when using the DR to receive incoming calls, and having DTMF options to transfer to an extension, if the extension is unregistered the remote caller hears "Call Transfer Failed" and then are dumped back into the DR.
    I assume this is by design - my question is whether there's the option of sending to the extension's voicemail if the call transfer fails? (without having to specifically have that as a DTMF option in it's own right)
    Cheers,
    Mike.
  2. Mori
    Mori New Member
    Mar 23, 2007
    223
    Have you set the option under forwards on the ext.?
    "Transfer to VM if unregistered".
  3. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    Yes, that's set properly.
