I Broke Outbound Calling
Discussion in '3CX Phone System - General' started by JCLloyd, Oct 11, 2017.
  1. JCLloyd
    JCLloyd New Member
    Oct 5, 2017
    112
    19
    Classic Newbie thing... I am going through making little changes, when I realize that I can no longer make outbound calls! In the Console Log, I get "[Flow] Target endpoint for ########### can not be built!". On the 3CX client, I get "Call failed, not found."
    . What did I do?? I was working a few days ago. I am still in test and trying things, but not for long. Help!
    . I found several threads of people running into this issue, but many of them stop without a solution or their fixes are not fixing what I did.
    So, I was doing or know...
    - I changed Extension Options; The "PBX Delivers Audio" radio doesn't seem to change things
    - I deleted Groups {Not Default} & Ring Groups that I created; Need to recreate differently
    - Inbound/Outbound rules are not changed from when working
    - I integrated Office365.zip and added to all extensions.
    - I entered a dialing code for Paging
    - I shut down the system and restarted it
    - the last time it worked was on Friday, and it is now Tuesday.
    Thank you, in advance, for pointing a newbie in the right direction!
  2. JCLloyd
    JCLloyd New Member
    Oct 5, 2017
    112
    19
    Update... All my SIPs are busy on inbound, too.
  3. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    848
    125
    Sorry can not help you why it is not working
    Do you have a backup when it was running, if so you could do a restore from this backup
    JCLloyd likes this.
  4. JCLloyd
    JCLloyd New Member
    Oct 5, 2017
    112
    19
    I didn't want to do that. I don't learn much that way. But, I had last night's backup, which got me back to working SIPs. It looks like I was only getting a single-day snapshot, so I just changed that.
    Saqqara, you did get me back to a working PBX! Now, to figure out what I broke, and how I broke it!
  5. Saqqara
    Mar 12, 2014
    848
    125
    This is how you learn - by breaking things and understanding why
    Do one step at a time - do backups and restart the system to make sure it works
  6. leejor
    10,357
    224
    Check the status of the trunk. Is it registered? Place a call, then check the 3CX Activity Log to see where it went (or didn't). Is the destination number something that matches an entry in the outbound rules?
    The fact that inbound and outbound are affected, it sounds like a trunk problem.
