I can not connect a PSTN Gateway WellGate 3804A.
Discussion in '3CX Phone System - General' started by jmareco, May 11, 2007.
  1. jmareco
    Dec 3, 2006
    6
    I can not connect a PSTN Gateway WellGate 3804A. In the 3CX manual appears a D-Link or Micronet VOIP Gateway on page 42 and I saw that menues are the same as WellGate 3804A
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,971
    280
    Is is the same as the micronet interface? Unfortunately those devices are very old but they do work. Try making a call, even though the line does register. What happens? Can you post server status log?
