I can not fueling a pap2 linksysy
Discussion in '3CX Phone System - General' started by enlace, Dec 15, 2015.
  1. enlace
    Nov 13, 2015
    5
    Hi I have a problem can I not provision a linksys pap2 as remote extension, as I could help please I have a virtual pbx from 3cx cloud-based, and all the extensions have to be remote, as I can please help to provide this adapter
    11,083
    325
    The 3CX site used to have a section on provisioning both the FXO and FXS ports on an SPA-3102, the FXS portion is very similar to the PAP2. At the moment I can't find it, it may have been removed as they consider the devices "no longer supported". If you are doing the provisioning manually you can get the basics from most other Linksys device How-to's.
    http://www.3cx.com/sip-phones/cisco-spa501g/
    Since you are using it remotely, you will probably want to be sure that STUN is enabled. Where (what type of router you are behind) and what other, if any, SIP devices may be on the same remote network, will make a difference in how you provision the ATA.
