I cant access my management portal
Discussion in '3CX Phone System - General' started by Niels Clavaux, Apr 2, 2018.
  1. Niels Clavaux
    Mar 23, 2018
    Hoi Peepz,
    Since this morning I can no longer reach my management portal so I can not change the setting of my PBX.
    In the customer portal only FQDN: Released
    FQDN IP: Released
    I have been waiting all day, but things are not working. Can someone give me tips?
    Thanks for helping.
    Gre Niels
    S&L Media
  2. jimbo59
    jimbo59 Member
    Nov 17, 2017
    342
    75
    How long has it been up? How many calls do you make a month?
  3. Niels Clavaux
    Mar 23, 2018
    Hoi,
    I am sure that i make more than 5 calls. Its up form the 10th of march. I use the pbx a lot. The strange thing is when i call my normal number its normal working. Only i cant access the panel and i cant login the extensies.
  4. bensonave
    Jan 4, 2018
    5
    Did you try a different browser?
  5. Saqqara
    Saqqara Active Member
    Mar 12, 2014
    692
    99
  6. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    674
    101
    Was this a PBX trial express instance? I believe those shutdown after 30 days.
  7. Niels Clavaux
    Mar 23, 2018
    Thanks for your help.
    I test the options that you give to me. I cant access the ip that 3BX give with the installation, also with port 5001 and 5002.
    I make a contract for free for one year, see attachment. I use a check a lot of things, mobile phone with 4G and WiFi. Computer with Chrome, IE, Firefox.
    I see with mxtoolbox.com, that there no record for the servername, that the resone that is not working, but why.
    Again, for my customers, they can call to the PBX, its fully working, but I cant login to the extensions, and to my admin panel. I think is a dynamic IP, but I don't no what to new ip is.
    Can I contact 3cx directly?
    Moderator Edit: removed screenshots
    #7 Niels Clavaux, Apr 3, 2018
  8. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,226
    60
    @Niels Clavaux
    I checked what happened and it seems that someone had removed the binding of your FQDN from your License Key. This resulted in your FQDN not resolving to the Public IP. The rest of the instance was working fine. This does not explain why you couldn't log in using the Public IP, I can only assume you were using the wrong one.
    Did you happen to log into customer.3cx.com and release the FQDN from the key?
    Anyhow, it should be working now.
