I cant get a gn LED at 3CX Phone System Line Status
Discussion in '3CX Phone System - General' started by voipxst, Dec 4, 2007.
  1. voipxst
    Dec 4, 2007
    I dont know we the status is still " Not registered"
    I have done the settings at the 3CX Server likes below
    Proxy server IP or FQDN: 90.187.202.238:5060
    User ID: xxxx
    Authentication ID: xxxx
    Password: xxxx
    I have done the settings at my 3CX VoIP Client likes below
    3CX PhoneSysem Server : 90.187.202.238
    My Extention Number: xxxx
    My VoiceMail Pin Number: xxxx
    Regards Bernd
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    On your Voip Client you should use the ip of your 3CX Box and not the IP of the (i believe it is) Voip Provider....
    Cheers
  3. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    Cannot edit so here it goes....
    Noticed also, with the options you said below you're using call assistant....
    Call assistant wont allow you to make Voip Calls by itself, you need a SIP Phone, hardware or by software.... you can use 3cx Voip Phone found here http://www.3cx.com/VOIP/3CXPhone.exe
    Cheers
