Hello @Arturo
First and most important: Never post support info in the forum. Therefore i have deleted them.
If you are using a non supported provider which is never recommended try using the Generic template as that has more "generic" settings and not specific settings for providers .
Regarding the issue you are facing from the provided files i can see that there is a Cancel message arriving from your provider the same second the Invite arrives.
I would recommend contacting your provider and asking them why they the cancel message immediately after the invite. Or use a supported provider that has been tested by 3CX and we can further assist if there is an issue.
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
