I can't register the GXW4104
Discussion in '3CX Phone System - General' started by carlosar, Jan 8, 2008.
  1. carlosar
    Jan 7, 2008
    15
    I can't register the GWX4104
    I tried several times to register it, followed all the steps, revised all the conections, checked the server, upgraded the firmware, checked the password for all the lines, the server has 2 phones registered already, all IP adress are ok, I tried with two differents servers everything is in the right way but still doesn't get registered. This is a test that I'm doing at home and I wan't to isntall it at the office so if it works I'll install it on all the offices. But I'm stucked in something that I think it's so simple. Please help me out!!!
    Thanks in advance.
  2. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Can you post the server status log when it tries to register. That will help us out to see what's going on. Could be a number of things.
  3. carlosar
    Jan 7, 2008
    15
    Ok, meanwhile I was trying to register them I recieve a call and surprisingly it register by itself. But the thing is I can't make calls.
    This is the log:
    20:13:53.838 Call::RouteFailed [CM503014]: Call(24): Attempt to reach [sip:004166061235@192.168.0.6;user=phone] failed. Reason: Not Registered
    20:13:53.833 Call::RouteFailed [CM503014]: Call(24): Attempt to reach [sip:004166061235@192.168.0.6;user=phone] failed. Reason: Not Registered
    Please note that I want to call to this external number:04166061235.
    The rule is done. Its made like this: calls that starts with 0 Route 1: GXW4104 remove 1 digit. Please note that maybe differs the words cause is in another language. but I'm pretty sure is well done. I followed all the rules. Its like it tries to connet to another extension that doesn't exist.
    Other curious thing is that even that I can register the soft phones at the PBX and I can make calls. I cannot recieve at them. This is the log:
    [CM503003]: Call(2): Call to sip:102@192.168.0.6:5060 has failed; Cause: 408 Request Timeout; internal
