- Joined
- Jun 28, 2007
- Messages
- 415
- Reaction score
- 0
Good morning,
After much celebration I am able to recieve calls on a BroadVoice line fine on my 3CX V5 server. The line registers fine and most everything looks ok until I attempt to call out on it. When I attempt to call out I get a fast busy signal and the following logs appear:
08:57:30.196 Call::Terminate [CM503008]: Call(3): Call is terminated
08:57:30.176 Call::RouteFailed [CM503013]: Call(3): Attempt to reach [sip:[email protected];user=phone] failed. Reason: Reason Unknown
08:57:30.176 CallLeg:nFailure [CM503003]: Call(3): Call to sip:[email protected] has failed; Cause: 400 Bad Request; from IP:147.135.12.221
08:57:30.066 MediaServerReporting::SetRemoteParty [MS210002] C:3.3:Offer provided. Connection(transcoding mode): xxx.xxx.xxx.xxx:52561(52562)
08:57:30.006 CallLeg:nFailure [CM503003]: Call(3): Call to sip:[email protected] has failed; Cause: 400 Bad Request; from IP:147.135.12.221
08:57:29.605 CallCtrl:nSelectRouteReq [CM503014]: Call(3): Target is not registered: VoIPline:xxxxxxx dialed on (AnyLine@BV1)
08:57:29.605 Line::Line [CM303003]: There are no available outbound lines on gateway BV1 at this time.
08:57:29.605 MediaServerReporting::SetRemoteParty [MS210002] C:3.2:Offer provided. Connection(transcoding mode): xxx.xxx.xxx.xxx:52559(52560)
08:57:29.395 MediaServerReporting::SetRemoteParty [MS210000] C:3.1:Offer received. RTP connection: xxx.xxx.xxx.xxx:2224(2225)
08:57:29.395 CallCtrl:nSelectRouteReq [CM503004]: Call(3): Calling: VoIPline:10000@[Dev:sip:[email protected]:5060, Dev:sip:[email protected]:5060]
08:57:29.365 Extension:rintEndpointInfo [CM505001]: Ext.101: Device info: Device Identified: [Man: Polycom;Mod: SoundPoint IP 330;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [PolycomSoundPointIP-SPIP_330-UA/2.1.1.0037] Transport: [sip:xxx.xxx.xxx.xxx:5060]
08:57:29.335 CallCtrl:nIncomingCall [CM503001]: Call(3): Incoming call from Ext.101 to [sip:[email protected];user=phone]
08:57:10.725 ClientRegs:nSuccess [CM504004]: Registration succeeded for: 10000@BV1
08:57:10.064 ClientRegs::Register [CM504003]: Sent registration request for 10000@BV1
I noticed in one line for capabilities it has "recvonly". Is that the problem?
Any ideas?
Thanks again for all the patience and help.
Any ideas?
