I do not obtain to add an extension.
Discussion in '3CX Phone System - General' started by irmelo, Mar 23, 2007.
  1. irmelo
    Mar 10, 2007
    When I go to the manage of extensions, after creating some extensions, them had not been save.
    I do not obtain to import extensions.
    Not I obtain to use editing nor deletar extensions.
  2. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    Could you please rephrase that ?
    It seems that you cannot add extensions. Is this when you do it via import only ?
