I dont know where to even start
Discussion in 'Call Flow Designer' started by viraltechnology, Nov 8, 2017.
  1. viraltechnology
    Mar 22, 2015
    39
    6
    We are working on a idea using CFD. We have two support queues tier 1 and tier 2. Tier2 is under untilized. We would like 75 % of calls to support to go to tier 1 and 25% to go to tier 2. I asked support about this and they said no, we can not do that default out of the box but suggested CFD may be able to help. I have downloaded and installed it on my pc. I have no idea what C3 expression to use any suggestions or perhaps good resources? we dont have to do percentages, if I can say 75 out of 100 calls to support will go to tier 1 and 25 will go to tier 2 thats fine as well. or 1 out of 4 calls....
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,684
    132
    Hello @viraltechnology,
    You can do this very easily with the CFD. Create a new project, add a "Create a condition" component to the callflow, and configure it with 2 branches. For the Condition of the first branch, you can use the following expression, so it's executed 75% of the times:
    Code:
    new Random().Next(100) < 75
    Leave the condition of the second branch empty, so it's executed when the first condition is not met.
    Then, in the first branch add a Transfer component and configure it to send the call to tier 1. And do the same for the second branch, sending the call to tier 2.
    Finally, build the project, create a new empty queue without agents, upload the CFD app to this new queue, and route your inbound calls to this CFD queue.
    Kind regards.
    viraltechnology likes this.
  3. viraltechnology
    Mar 22, 2015
    39
    6
    I will try this today! Thank you.
  4. viraltechnology
    Mar 22, 2015
    39
    6
    @er
    We just finished testing and this works like a charm!! thank you!
