I have a problem with outbound calls.
Discussion in '3CX Phone System - General' started by Andrew.aitken, Mar 14, 2012.
  1. Andrew.aitken
    Mar 14, 2012
    Hello
    16:42:08.353 [CM503020]: Normal call termination. Reason: Not found
    16:42:08.353 [CM503016]: Call(2): Attempt to reach <sip:0418869999@192.168.87.14> failed. Reason: Not Found
    16:42:08.352 [CM503003]: Call(2): Call to sip:0418869999@sip.wa.iinet.net.au:5060 has failed; Cause: 404 Not found; from IP:203.59.49.10:5060
    16:42:08.213 [CM503025]: Call(2): Calling VoIPline:0418869999@(Ln.10000@Generic VoIP Provider -)@[Dev:sip:0864608217@sip.wa.iinet.net.au:5060]
    16:42:07.885 [CM503004]: Call(2): Route 1: VoIPline:0418869999@(Ln.10000@Generic VoIP Provider -)@[Dev:sip:0864608217@sip.wa.iinet.net.au:5060]
    16:42:07.885 [CM503010]: Making route(s) to <sip:0418869999@192.168.87.14>
    16:49:25.771 [CM504004]: Registration succeeded for: 10000@Generic VoIP Provider -
    16:49:25.422 [CM504003]: Sent registration request for 10000@Generic VoIP Provider -
    Assigned Codecs are G.711 A & U
    Any Idea's
  2. Andrew.aitken
    Mar 14, 2012
    Found it
    sip server is iinetphone.iinet.net.au
    sip proxy is sip.wa.iinet.net.au
  3. leejor
    10,781
    287
    Are you sure that 0418869999 is a valid number, and is in a valid format (prefix, number of digits), for your particular provider. It appears they don't like something about it.
