I have a very interesting question
Discussion in '3CX Phone System - General' started by lcastro, Apr 13, 2016.
  1. lcastro
    Apr 13, 2016
    Can I record a massage and send via my pbx automaticly to random numbers or a list of numbers?
    10,362
    227
    Not without some sort of add-on product.
    Sending anything to "random" numbers, sounds...annoying, and possibly, illegal.
  3. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    The quick answer is no. As leejor indicated, 3CX is not capable of this out-of-the-box.
    There may be some legal issues that need to be considered depending upon the laws in your country. There are 3rd party auto-dialers that can be integrated with 3CX. In the U.S, there is a do-not-call registry. This is a listing of phone numbers that have indicated that unless certain conditions are met, the numbers are not to be called. There may also be requirements that if a number is called, that an option has to be presented that allows the callee to opt out of any future calls. There may be other reqiurements as well.
    It can be done, just be sure to follow the law.
