I have forgotten how to do this....
Discussion in '3CX Phone System - General' started by godskitchen, Jul 21, 2016.
  1. godskitchen
    Nov 27, 2013
    17
    Hello all,
    I need a little help....
    I want to change the ring tone that a customer hears when they call our phone system.
    It is currently a progress tone like you would expect.
    I am sure I have changed this before but I can not find the file I need to replace anywhere.
    Can anyone shed some light please?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,064
    58
    This is typically not possible as the tones have specific frequencies, rates, etc, that have meaning/signalling when on the outside PSTN network and are carrier generated.
    Now then, once the call is answered and moved around internally you can have a recording of a desired ringtone that the caller will hear.
    You can also change the ringtone on your internal phones, for calls coming in (received) but this is done by alert-info SIP messages that then correlate to a tone pre-loaded into the phone. It may also be done on some phones based upon the received caller-id so that a specific caller (such as the boss) can be uniquely identified.
    Think of the mobile/cell phone, The caller will always hear the standard ring-back tone as provided by the (usually) delivering carrier; yet the person being called may have a custom ring tone that is only played/heard by the person being called...not the caller.
  3. leejor
    10,563
    245
    It all depends on how you expect this to work. As mentioned, the initial customer ringback is provided by either the originating provider, or your (terminating) provider. This can vary, depending on whether audio is cut through before answer supervision (an SS7 thing). So, until 3CX actually answers the call, you have no control over what the caller hears. At the point of answer, ringback should stop, and the caller is connected to a queue, person, Digital receptionist, etc. The ringback tone they hear after that is internal and usually decided upon based on the country the PBX is located so as not to confuse most users. Any change to the ringback tone-set will affect all callers on the PBX, internal, and on external callers, when being transferred.
  4. godskitchen
    Nov 27, 2013
    17
    Yes, sorry I should have been more clear, I want to change the tone after the call is answered internally.
    I have done it before, I changed what I thought was called "US Progress Tone" now I can't find it.
    This site does not really put people on hold so I want the progress tone once the call is answered by a digital receptionist and give a promotional message.....
    Any ideas?
  5. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    now I wonder why there is only 1 such tone - USProgresstone.wav(look in comments) :?:
