I HAVE PROBLEMS WITH VOIP REGISTRATION
Discussion in '3CX Phone System - General' started by nbernalr, Jan 22, 2008.
  1. nbernalr
    Nov 19, 2007
    I DONT KNOW WHAT HAPPEN BUT WITH VERSION 3.1 ALL WORKS FINE BUT SINCE INSTALLED V5 I HAVE THIS PROBLEM I TRIED TO RETURN TO V3 BUT STILL I HAVE THE SAME PROBLEM
    08:11:40.781 StratInOut::eek:nHangUp [CM104007] Call(1): Call from Ext.100 to 8500 has been terminated by Ext.100; cause: CANCEL; from IP:172.16.1.49
    08:11:32.218 MediaServerReporting::STUN [MS101003] Call(1) Ln:10000@VoIP Sureste: Possible firewall problem. Address mapping failed on STUN server 208.239.76.163:3478 for local address ":9000"
    08:11:25.531 CallConf::eek:nIncoming [CM103002] Call(1): Incoming call from 100 (Ext.100) to sip:08500@172.16.1.47
    08:10:54.796 ListenConnect [CM114000] SL: connected server:0/PHPExtension_0 at [server]/PHPExtension_0
    08:10:50.312 ClientRegs::eek:nRequestRetry [CM113008] Registration attempt for Ln:10000@VoIP Sureste is scheduled in 480 sec.
    08:03:35.859 ClientRegs::eek:nRequestRetry [CM113008] Registration attempt for Ln:10000@VoIP Sureste is scheduled in 360 sec.
    07:59:03.562 ClientRegs::eek:nRequestRetry [CM113008] Registration attempt for Ln:10000@VoIP Sureste is scheduled in 240 sec.
    07:56:31.234 ClientRegs::eek:nRequestRetry [CM113008] Registration attempt for Ln:10000@VoIP Sureste is scheduled in 120 sec.
    07:54:24.656 ClientRegs::eek:nSuccess [CM113005] Registration of sip:3132740@sip.voipmatrix.com is successful
    07:54:20.125 ExtLine::Register [CM110004] Send registration for <sip:3132740@sip.voipmatrix.com>
    07:54:20.125 ExtLine::Register [CM110003] Use both (External and Internal) IPs for device line registration DN='10000' device='VoIP Sureste'
    07:53:38.937 ClientRegs::eek:nRequestRetry [CM113008] Registration attempt for Ln:10000@VoIP Sureste is scheduled in 360 sec.
    07:46:41.437 ClientRegs::eek:nRequestRetry [CM113008] Registration attempt for Ln:10000@VoIP Sureste is scheduled in 240 sec.
    07:45:29.000 ClientRegs::eek:nSuccess [CM113005] Registration of sip:3132740@sip.voipmatrix.com is successful
    07:44:19.765 ClientRegs::eek:nFailure [CM113010] Next registration will be attempted in 10 minutes
    07:44:19.765 ClientRegs::eek:nFailure [CM113006] Registration of sip:3132740@sip.voipmatrix.com has failed; reason=Request Timeout
    07:43:23.468 ClientRegs::eek:nRequestRetry [CM113008] Registration attempt for Ln:10000@VoIP Sureste is scheduled in 120 sec.
    07:43:14.046 ServRegs::eek:nAdd [CM113002] Registered: Ext.101
    07:43:13.953 ServRegs::eek:nAdd [CM113002] Registered: Ext.100
    07:43:07.328 ClientRegs::eek:nSuccess [CM113005] Registration of sip:3132740@sip.voipmatrix.com is successful
    07:42:52.890 IVRConnected [CM111000] IVR Server is connected
    07:42:52.890 ListenConnect [CM114000] SL: connected server:5483/IVRServer at [server]/IVRServer
    07:42:51.125 ExtLine::Register [CM110004] Send registration for <sip:3132740@sip.voipmatrix.com>
    07:42:51.125 ExtLine::Register [CM110003] Use both (External and Internal) IPs for device line registration DN='10000' device='VoIP Sureste'
    07:42:50.937 StunClient::process [CM115002] STUN resolved external IP=201.147.157.222:20775 by server 64.69.76.23
    07:42:50.828 ExtLine::Register [CM110004] Send registration for <sip:3132740@sip.voipmatrix.com>
    07:42:50.828 ExtLine::Register [CM110003] Use both (External and Internal) IPs for device line registration DN='10000' device='VoIP Sureste'
    07:42:50.515 StunClient::process [CM115002] STUN resolved external IP=201.147.157.222:20775 by server 64.69.76.23
    07:42:50.406 StunClient::process [CM115001] Send initial STUN request to 64.69.76.23
    07:42:50.296 CallMgr::Stack::thread [CM106001] ** Enter Stack Loop **
    07:42:49.203 ServRegs::checkExpiration [CM113000] Registration for sip:101@172.16.1.47 has expired
    07:42:49.171 ServRegs::checkExpiration [CM113000] Registration for sip:100@172.16.1.47 has expired
    07:42:49.156 CallMgr::DumThread::thread [CM100004] ** Enter DUM Thread **
    07:42:48.953 DBA [CM109000] ** Database connection Ok **
    07:42:48.875 ListenConnect [CM114000] SL: connected server:0/VoiceBoxManagerService at [server]/VoiceBoxManagerService
    07:42:48.765 MediaServerConnected [CM112000] Media Server is connected
    07:42:48.765 ListenConnect [CM114000] SL: connected server:0/MediaServer at [server]/MediaServer
    07:42:48.718 CallMgr::Stack::Initialize [CM106000] ** Adding transports **
    07:42:48.718 CallMgr::Initialize [CM100003] ** Initializing SIP stack **
    07:42:48.718 CallMgr::Initialize [CM100002] Default Local IP address: 172.16.1.47:5060
    07:42:48.531 CallMgr::Initialize [CM100001] Version: 3.1.2434.0
    07:42:48.531 CallMgr::Initialize [CM100000] Start 3CX PhoneSystem Call Manager
    07:42:48.531 LoadLicenceInfo [CM100007] Licence was loaded successful
