I have PSTN's but what is this...
Discussion in '3CX Phone System - General' started by scu, Feb 10, 2008.
  1. scu
    scu
    Jan 26, 2008
    19
    I am only using two PSTN lines and my server logs shows this ever 10 seconds.. what is it that I missed? It says that to disable STUN, delete the entries, so I don't have an entry in the STUN settings under General Settings Page except for the Port Numbers that won't go away.
    Anyone please tell me what I can do to make this go away.. again, it goes every 10 seconds..
    I have a Grandstream GXW 4104 Gateway, with 3cx Ver 5.0 Build 3790. Thanks.
    22:25:53.296 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    22:25:43.203 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    22:25:33.140 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    22:25:23.078 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    22:25:12.984 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    22:25:02.906 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    22:24:52.843 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    22:24:42.765 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    22:24:32.687 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    22:24:22.625 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    22:24:12.546 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    22:24:02.484 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    22:23:52.390 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    22:23:42.312 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    22:23:32.250 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    22:23:22.156 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    22:23:12.078 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    22:23:02.015 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    22:22:51.937 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    22:22:41.859 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    22:22:31.796 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    22:22:21.718 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    22:22:11.640 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    22:22:01.578 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    22:21:51.500 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    22:21:41.421 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    22:21:31.359 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
    22:21:21.281 StunClient::loadStunList [CM306002]: There is no valid STUN server specified! External IP can not be resolved.
  2. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    Go through the firewall checker and ensure you pass?
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,926
    241
    I suggest upgrading to 5.1. You can then remove the stun server check by emptying the stun server setting in general settings, this wil make the check stop.
  4. scu
    scu
    Jan 26, 2008
    19
    Thanks I'll try upgrading, though I am a little hesitant to upgrade because of the uncertainty of previous updates, I think I will just go for it ..
  5. paragondie
    Jun 25, 2007
    52
    We are running Version 5.1.4128.0 with no entries in the stun server options under general setttings (the port numbers keep regenerating in the fields) and we are scrolling the same message "There is no valid STUN server specified! External IP can not be resolved."
  6. paragondie
    Jun 25, 2007
    52
    Bump
  7. josvic
    Apr 24, 2007
    51
    I have the same issue... in one of my external lines (out of the home-net) I get the same error: There is no valid STUN server specified! External IP can not be resolved.
  8. banksy
    12
    We are getting the same problem.
    We have a static IP no nat, so have no reason to use STUN, infact our provider requires us not to use stun.
    Any suggestions? the field are blank
  9. josvic
    Apr 24, 2007
    51
    Any suggestion?
  10. h2009
    h2009 Member
    Mar 15, 2008
    447
    The function cannot be turned off. You need to have the stun address, or set the delays between each stun high.
