I hear them, they can't hear me
Discussion in '3CX Phone System - General' started by ndraves, Nov 20, 2009.
  1. ndraves
    Jul 22, 2007
    29
    Hi. I have two Grandstream GXP-2000 phones. I'm using Skype for my service provider.
    When I get a call, I hear them just fine, but they can't hear me at all. Does anyone have any ideas?
    Thanks!
    11,117
    329
    It could be a number of things but I suspect that some ports aren't open. What sort of router/firewall are you using and what ports have you forwarded to the IP of the computer running 3CX? Have you followed the information available on the 3CX site?
  3. ndraves
    Jul 22, 2007
    29
    At this point, I have the server on a public IP address, so all ports are open.
  4. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,972
    281
    This is a typical firewall / nat problem. Your server could be on a public IP but you could still be passing via a NAT device for the phone or even one located at the ISP that you are not aware of!
  5. ndraves
    Jul 22, 2007
    29
    Could it have something to do with Windows Internet Connection Sharing?
  6. aveiser@veiser.de
    Dec 23, 2008
    23
    You should control proper setting of default gateway-ip on oll devices
  7. ndraves
    Jul 22, 2007
    29
    The PBX is set to deliver audio in the PSTN settings.. The default gateway for both phones are set to the address of the NIC in the 3CX server for that subnet.
    Thanks for the suggestions, though.
    Any other ideas?
