I need change the RingPCSpeaker VOLUME configuration. How?
Discussion in 'Windows' started by jacolino, Aug 15, 2011.
  1. jacolino
    Jul 11, 2011
    The configuration is in the 3cxphone file configuration: "%USERPROFILE%\AppData\Local\3CX VoIP Phone\3CXVoipPhone.ini"
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,502
    69
    Re: I need change the RingPCSpeaker VOLUME configuration. Ho
    PC speaker is, well, only a speaker, you cannot change its volume, it has nothing to do with the sound card. This kind of beep is used, for instance, in cold boot diagnostics when memory, CPU or graphic card fails.
