i need help from my friend
Discussion in '3CX Phone System - General' started by tariq, Aug 16, 2010.
  1. tariq
    Aug 16, 2010
    5
    hi friend ..
    i need help
    i work in company and i want to make communicate all departments in company by VOIP phone ..
    how can do that , and what is the right software can help me to do that , and how it work
    so i am grateful for every body can help me
    regards ...
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,455
    92
    Hi friend :lol: ,
    Talking about VoIP can be a lengthy subject so i'm only going to tell you about the basics. I'd suggest you do some Google searching regarding PBX's and VoIP to learn more.
    1) You will need a PBX. You can think of a PBX as a big box where all calls are managed from automatically for you.
    You can download and install the 3CX PBX for this.
    2) You will need to either get Software Phones that you can install on each PC and Use Headphones / Microphones instead of buying real phones. Or you can just buy real VoIP Phones, connect them to your Local Router / Network. Then you would need to configure them correctly so that they connect to the PBX.
    Now, i can't really sit and type 2 pages of information on how to configure your Phones and PBX, you will have to do some research on what a PBX is and how it works before proceeding.
  3. mfm
    mfm Active Member
    Mar 4, 2010
    641
