I need help
Discussion in '3CX Phone System - General' started by dewon2, Sep 28, 2008.
  1. dewon2
    May 19, 2008
    9
    Many of my employees want to connect to the phone system that we have at work at home. Is there a way to do this? Please help me!
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,991
    306
    Yes, if you have 3CX Phone System this is possible. I suggest you contact a 3CX reseller and get a quote for an edition and installation support....
  3. worksighted
    worksighted New Member
    Aug 19, 2008
    204
    What ype of phoens are you using?
    Mike
  4. dewon2
    May 19, 2008
    9
    We are using the 3CX VoIP Phone Client. I have the free edition working right now for environmental testing. Will this work?
    and I am using a Belkin Router, so how do I go about unblocking the ports?
  5. Discovery Technology
    Apr 19, 2008
    278
    The voipclient user manual goes into some pretty good details regarding which ports to use (and open) through your Belkin router.
    If you're still having trouble with the setup after that, a local 3CX reseller could probably get you up and running within a couple of minutes as the setup shouldn't take too long to get going.
    Cheers, Brendan
