I really need help with the SPA3102
Discussion in '3CX Phone System - General' started by dete, Sep 17, 2007.
  1. dete
    Sep 12, 2007
    11
    My 3cx System
    3CX3.1.2434.0
    My device
    SPA3102 with 5.7 fimeware
    My Log
    09:51:19.500 MediaServerReporting::RTPReceiver [MS105000] Call(64) Ln:10000@Linea 1: No RTP packets were received on 00000078@:remoteAddr=192.168.0.60:16394,extAddr=0.0.0.0:0,localAddr=192.168.0.131:7228
    09:51:19.500 MediaServerReporting::RTPReceiver [MS105000] Call(64) Ext.100: No RTP packets were received on 00000077@:remoteAddr=192.168.0.131:7000,extAddr=0.0.0.0:0,localAddr=192.168.0.131:7226
    09:51:19.500 StratLink::eek:nHangUp [CM104001] Call(64): Ln:10000@Linea 1 hung up call; cause: BYE; from IP:192.168.0.60
    09:51:19.187 CallLegImpl::eek:nConnected [CM103001] Call(64): Created audio channel for Ln:10000@Linea 1 (192.168.0.60:16394) with Media Server (192.168.0.131:7228)
    09:51:19.187 StratInOut::eek:nConnected [CM104005] Call(64): Setup completed for call from Ext.100 to Ln:10000@Linea 1
    09:51:19.187 CallLegImpl::eek:nConnected [CM103001] Call(64): Created audio channel for Ext.100 (192.168.0.131:7000) with Media Server (192.168.0.131:7226)
    09:51:17.187 CallConf::eek:nProvisional [CM103003] Call(64): Ln:10000@Linea 1 is ringing
    09:51:17.093 CallConf::eek:nIncoming [CM103002] Call(64): Incoming call from 100 (Ext.100) to sip:0685349220@Dekora
    My configuration SPA3102
    VoIP-To-PSTN Gateway Enable: yes
    oIP Caller Auth Method: none
    VoIP PIN Max Retry:
    One Stage Dialing: yes
    Line 1 VoIP Caller DP: none
    VoIP Caller Default DP: none
    Line 1 Fallback DP: none
    My conf 3cx gateway
    Gateway Hostname or IP = 192.168.0.60
    Gateway Port (default is 5060) = 5060
    Use registration's 'Contact' field host/port instead host/port specified in configuration = NO
    Require (optionally: authorized) registration for: Nothing (doesn't require registration at all) = Both in-out calls
    Supports Re-Invite = YES
    Supports 'Replaces' header = NO
    'To.user' field = YES
    'Request-Line-URI' field = YES
    'RemotePartyID;party=called' field = YES
    Gateway is external = NO
    PBX delivers audio = NO
    Use IP in 'Contact' to recognize source = NO
    IP Range = EMPY
    Caller-ID is in 'user' part of (one of following): = 'From' field
    'To' field
    Called-Number (for inbound calls) is in: = 'To.user' field
    Client X-lite 3.0
    Location = Spain
    My problem
    I can recibe calls over the linksys line, but I can't make out calls by the linksys line, for the hung up error. please can anybody help me?
    Thank for your help
  2. dete
    Sep 12, 2007
    11
    Finally Solved
    PSTN Disconnect Detection
    Detect CPC: no
    Detect Polarity Reversal: no
    Detect PSTN Long Silence: no
    Detect VoIP Long Silence: no
    Detect Disconnect Tone: yes
