I RECEIVED CALL BUT OUTBOUND CALL DOESN'T WORK
Discussion in '3CX Phone System - General' started by gbf3cx, Sep 17, 2009.
  1. gbf3cx
    Sep 17, 2009
    I setup a Skype into my phone system, I received call and work great but I doesn't make a call for skype from my phone system, in the server log appear temporarily unavailable.
    HELP
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,531
    69
    Please try to provide a (more) detailed description, it will be useful for everybody, mainly you and me :mrgreen:
    Until then, just tell me when you call from your phone Skype's sound service, what you get?
    regards
    vali
  3. gbf3cx
    Sep 17, 2009
    Ok, when I call from outside line to the skype work perfect, sound good no problem, but when I place a call form the PBX I gave a fast busy and I check the server log and I get temporary unavailable.
  4. Vali_3CX
    Dec 12, 2008
    1,531
    69
    Sorry, this is not a more detalied description or the answer to my question about Skype's sound service, it's the same description in other words :roll:
  5. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Could you please specify the "destination number" and specify "how do you dial it?" ?
  6. webguyz
    webguyz New Member
    Jul 19, 2007
    126
    Did this ever get resolved? I just installed the Skype Gateway and getting the same error for outgoing calls:
    09:56:21.376 [CM503003]: Call(6): Call to sip:214xxxxxx@72.xx.xx.xx:6060 has failed; Cause: 480 Temporarily Unavailable; from IP:72.xx.xx.xx:6060
    Thanks!
  7. webguyz
    webguyz New Member
    Jul 19, 2007
    126
    Never Mind! I didn't have the country code :roll:
  8. bilalamjad3
    Feb 6, 2010
    6
    check your country code.
