i use vbuzzer,i can call outbound ,but i cannot receive inco
Discussion in '3CX Phone System - General' started by Anonymous, Sep 4, 2006.
  1. Anonymous
    Anonymous Guest
    http://www.vbuzzer.com ,i use them service ,i can use 3cx phone to make outbound call, but cannot receive it .the system can ring ,but can not hold it .
    so can you test that for me ? thanks .
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    304
    New beta
    Thank you for your feedback.
    I suggest you wait for the next beta, which should be available over the coming few days. This has many improvements in relation to the VOIP provider setup.
    If the problem then persists we will work with you to fix it.
