I would like to change The prompts
Discussion in '3CX Phone System - General' started by codigit, Sep 11, 2007.
  1. codigit
    Mar 1, 2007
    25
    Hey hello i would like to change the standar english promt set...
    i mean i want that when is transfering the call say in "Spanish" not in english, is that possible??
    for example you cal and say " Presione 1, presione 2, Etc..." so say "your call is being transfer" i would like "su llamada esta siendo transferida" i mean in spanish?
    How can i change thats file?? where is saved?
  2. tab
    tab
    Aug 10, 2007
    85
    This is very simple, 3CX is great.
    You can find it on the left menu - general settings - system prompts. You have to make a copy of standard prompts then you can change all of the prompts. Otherwise 3CX has spanish prompts on list.
    tab
  3. codigit
    Mar 1, 2007
    25
    where can i download spanish prompts
    Hey where can i download the spanish prompts?
  4. tab
    tab
    Aug 10, 2007
    85
    hi,
    In general on system prompts page, you can click on "check for more prompts". Anyway the path of prompts is \3CX PhoneSystem\Data\Ivr\Prompts\Sets\. I have 3.1.2434.0 clear install.
    tab
